Results 1 to 13 of 16
Thread: list of HVAC Brands
06-01-2005, 07:51 PM #1
- Jun 2005
- 5
We are in the early stages of getting quotes for two different scenerio's.
Scenerio 1- keep 3.5 ton Tempstar split unit (furnace is verticle inside home) and just purchase a new furnace.
Scenerio 2- replace split system with a 4 ton all in one unit.
The first contractor is going to bid out both scenerios with a Trane and Rheems but wanted me to do research and see if there is any other brand we wanted quoted.
I have absolutely no clue where to begin to look to see how the Brands rank ie is Trane #1 seller in US or is it middle of the road??
Does anyone know a site that ranks the brands or can anyone tell me 4 or 5 name brands that aren't the MOST expensive NOR are the lowest. (looking for middle of the road cost).
Thanks so much for your help. I may have more questions as the bids proceed.
Toni
06-01-2005, 08:09 PM #2
Professional Member*
- Mar 2002
- Concord, CA
- 2,628
I'm sure someone will answer your question in due course toni. But if you'll indulge my two cents, you should spend 90% of your "furnace buying energy" on finding a good contractor and 10% on the rest. I'm sure the first guy seemed nice and all. But precious few contractors do everything that they should be doing on a new installation. You may think I'm exaggerating. But in my opinion if a homeowner got 4 bids he'd be lucky to have just one of those bids come from a contractor that was going to design and install the system by the book.
Focusing on the brand of your furnace would be like worrying whether or not your car will come with Bridgestone or Michelin tires. The car maker is vastly more important that the company supplying the tires. The same goes for your HVAC system. The equipment manufacturer only supplies components. The contractor actually builds it.
06-01-2005, 08:18 PM #3
- Sep 2001
- angola indiana
- 528
Well said! Now if we can just convince the other kajillion homeowners.
06-01-2005, 08:19 PM #4
- Jun 2005
- 5
Thank you. I will start looking for a reputable contractor in my area and start from there. Thank you.
Toni
06-01-2005, 08:21 PM #5
- Apr 2005
- 53
Well, not only does the quality of the installation obviously make a huge difference, but you also get what you pay for in the long run.
I would put Trane and Rheem nearly at opposite ends of the spectrum, with brands like Carrier and Lennox closer to Trane while Goodman, Payne and Heil down near Rheem.
But a lot of these brands are owned by the same manufacturer, which may put out their own units. For example, American Standard owns Trane.
Of course, each brand has several models and costs can range there too. Don't forget to look into that.
06-01-2005, 09:26 PM #6
Everyone has their own opinion on brands. We've sold the 2 you mention (in sister brands) for 15 years. I'd call both premium units. Lately however we've found A-S/Trane a bit less reliable than the Rheem brands. The manufacturer says they are going to put more emphasis on QC in the future. But even the best products will cause grief if not properly sized and installed and the low end will work fine if they are.
If your current A/C doesn't cause any trouble and isn't at the end of its life, keep it for a while. If you do decide to change it, why go bigger? Bigger is not better.
http://www.johnmills.net/compare/outdoorunits.htm
http://www.johnmills.net/compare/compare90.htm
06-01-2005, 11:28 PM #7
- Jun 2005
- 5
thoughts on route to go?
We have a 1958 house in Arizona. We have a 1997 TempStar 3.5 ton split 75,000 BTU unit. Estimated 10 Seer. (GNJ075M16CI). The original sq. footage was 1610 and we added on to make 1857. Once we added on we could not get any airflow in the added rooms and the rest of the house doesn't seem to be in balance and gets quite warm quickly when the system shuts off. We have had 3 technicians out and have been given 3 different recommendations. Could you give me your opinion as to which one sounds correct.
All 3 technicians recommend making some changes to the newly added ductwork, taking out the old unused evap system and adding insulation- which we will definately do.
Tech 1- said ah you need to have at least a 5 ton unit (new split system) to handle the square footage of the home.
Tech 2 (spent the most time here researching things) said that we definately need a new furnace as the one we have moves 1300cfm's and we need at least 1600cfm's and that the 3.5tons would work fine if we keep the avg temp at 78 for the 112degree average. If we want it lower (my husband likes 73 degrees) then he recommends getting a new 4 ton unit with a 2 system on it.
Tech 3- says to just do the duct work and insulation as the 3.5 ton system and furnace is fine and it SHOULD help with air flow in our add on but doesn't guarantee how long the furnace will last.
Any advice/recommendations would be helpful.
Thank you,
Toni
06-02-2005, 01:16 AM #8
- Mar 2002
- Concord, CA
- 2,628
Tech 1 is shooting from the hip. His aim ain't so good. Do a heat load calc and find out for yourself. Hit the bull’s-eye above.
Tech 2 sounds like he might be on the ball. If you read my link above I eventually talk about a 5 ton load that I cooled perfectly with 4 tons. There's more to it. But if you're in a dry climate then the simple explanation is LOTS of airflow with extremely tight ducts and a fat evaporator coil.
They may call me nuts. But unless you're going to do a LOT of duct upgrades then put in a furnace with a 5 ton blower. Put in a high efficiency coil that's one-half to one full ton bigger than the AC with a TXV. Upgrade the return to 20 inches. Then upgrade the duct to the rooms that don't get enough and/or put in dampers to force more air towards them (the decision there is best made with an onsite evaluation). Do those things and your 3.5 ton system will scream - I guarantee it.
I do dry climate AC and it's what I know. I took a miserably hot upstairs office that had a 2.5 ton system and inaccessible ducts. I put in a high efficiency (BIG) three ton coil on it with a four ton furnace blower and one of the ladies now has to wear a coat to work in summer. The air conditioner? The same 2.5 tons as before.
What's the furnace make and model?
06-02-2005, 01:20 AM #9
Banned
- Nov 2000
- Coastal Georgia
- 34,902
I wouldn't listen to anyone that places a Goodman near a Rheem and a Carrier near a Trane.
06-02-2005, 03:51 AM #10
- Mar 2002
- Concord, CA
- 2,628
http://www.hvac-talk.com/vbb/showthr...threadid=77259
It looks like you need to do a little thread consolidation.
Anyway, if your existing furnace does indeed have a 4 ton blower then you can work with it. Whatever route you take you need to get that airflow up and the ducts sealed.
06-02-2005, 06:31 PM #11
- Nov 2004
- SW FL
- 5,260
Mfg and Contractors
Lennox and TRANE will serve you well for a Longer time than most other manufacturers.Originally posted by toniv
.. we need at least 1600 cfm's and that the 3.5 tons would work fine if we keep the avg temp at 78 for the 112 degree average. If we want it lower (my husband likes 73 degrees) then he recommends getting a new 4 ton unit with a 2 system on it.
I would look at TRANE 4TTX 6048 / 4TEE3F 065E as a BASE a
and make just two or three other comparisons.
Also, inquire about 10 year Parts & Labor Warranty $ ____
http://www.trane.com/Residential/Pro...ableSpeed.aspx
http://www.trane.com/Residential/Pro...ers/XL16i.aspx
http://www.lennox.com/products/list.asp?type=1
http://www.lennox.com/products/overview.asp?model=HSX16
Maintaining < 77'F with a 3.5 Ton system ( depending on amount/type of glass + orientation ) is quite suspect for AZ as your local tech has already advised.
You may wish to add tinting on the West side windows.Designer Dan
It's Not Rocket Science, But It is SCIENCE with "Some Art".
06-02-2005, 10:09 PM #12
- Apr 2005
- 53
I may be a newbie with only 5 years under my belt, but one thing I know is that I'm pulling dead 8 year old goodman's out on a dialy basis and have yet to retro fit a Carrier. Whatever. To each their own.Originally posted by James 3528
06-02-2005, 10:19 PM #13
Here is a few more you might want to check out some are no longer in business but here is a list this should keep you busy for a while.
AAON:.
ADDISON PRODUCTS
AIRE-FLO
AIRQUEST:
AMANA:
AMERICAN FURNACE [AFCO.
AMERICAN-STANDARD:
ARCO:
ARKLA:
ARMSTRONG
BARD:
BOHN:
BRYANT:
CARRIER:
CENTURY:
CLIMATEMASTER:
COLEMAN
COMFORTAIRE:
COMFORTMAKER:
COMMAND-AIRE:
CONSOLIDATED
COOLERATOR, McGRAW-EDISON:
CRANE
CUMBERLAND:
DAIKIN US
DAY & NIGHTDELCO
DUCANE
DUNHAM-BUSH:.
DUOMATIC-OLSEN: ELECTRIC-FURNACE-MAN:
EUBANK:
FANDAIRE
FRASER-JOHNSTON
FEDDERS:
FRIEDRICH:
FRIGIDAIRE:
GAFFERS & SATTLER:
GENERAL ELECTRIC:
GREEN COLONIAL:
HALL-NEAL FURNACE:
HASTINGS
HEIL-QUAKER:
HENRY FURNACE [MONCRIEF]:
HOME FURNACE:
INTERNATIONAL COMFORT PRODUCTSINTERNATIONAL HEATER
INTERNATIONAL OIL BURNER:
INTERTHERM
IRON FIREMAN: ITT:
JANITROL:
JOHNSON, AIR-EASE:
LENNOX
LUXAIRE:
MAGIC CHEF:
MAYFLOWER:
MAYTAG:
McQUAY:
MILLER:
MITCHELL:
MONCRIEF:
MUELLER CLIMATROL.
NATIONAL U.S. RADIATOR (Capitolaire):
NESBITT: NIAGRA:
OLSEN:
ONEIDA-ROYAL:
PAYNE: PEERLESS
PEERLESS HEATER:
PERFECTION:
RHEEM:
ROUND OAK:
RUUD:
RYBOLT:
SILENT AUTOMATIC:
SINGER:
McQuay
SOUTHWEST MFG:
SPACE CONDITIONER:
SQUARE D:
STEWART-WARNER:
TAPPAN:
TEMPSTAR:
THERMOPRODUCTS:
TRANE:
TORRIDHEET:
WATERBURY:
WATERFURNACE:
WEATHERKING:
WESTINGHOUSE:.
WHIRLPOOL
WILLIAMS OIL-O-MATIC
WILLIAMSON:
WORTHINGTON:
YORK:
“I am glad that I paid so little attention to good advice; had I abided by it I might have been saved from some of my most valuable mistakes.” - Edna St. Vincent Millay
The critic is a prisoner to his own experiences and perspectives, erroneously believing his limited experiences are the sum of all truth.
No Guns…No Freedom…Know Guns…Know Freedom.
