Results 1 to 6 of 6
    May 2005
    hi guys i am new to this bussiness an i never installed new units only serviced.....
    i have to relocate this 2 condenser units 2 ton to the roof on the roof of a 2 flat apartment building...
    will it be any problem with the oil not coming back to the compressor since the evap is below the condenser somone told me they do some kinda trap like on the sinks..
    thanx a lot for any information...do i have to call a truck to put those condensers up on the roof or there are manual lifters that u put on the roof and pull the condenser up is not that big 2 ton 10 seer
    That doesn't make sense.
    Get back to work.™
    May 2005
    i worked with somone before he only let me service change parts i never personaly seen how they install the condensers on the roof only on the ground level thats what i meant.
    Crane !!!
    Oil return depends on line length, and size, and each manufacturer has their own recommendations, call them and ask.
    leland nc
    do one of two things here
    get some one to help you that knows how to do this
    walk away because you are in over your head already
    not trying to ofend you but from your questions and you admision you will get in to alot of problems
    May 2005
    ok thanx guys
