Results 1 to 13 of 15
    Feb 2011
    Irmo, SC
    pressure discrepancy - heat pump
    ok so a guy i work with (seriously, a guy i work with, not myself haha) was talking to me about an issue he was trying to diagnose. went to a heat pump call for a freezing condenser coil. pressure was low, so he added freon, then checked it in heating and cooling modes, and found a big discrepancy. pressure was too high in one and too low in the other mode (not sure which). a few people in the office think it is the reversing valve. the others think the filter dryer needs to be replaced. what would be a good way to find out? reasoning tells me that the bes idea is to first replace the dryer since it is a far less expensive and less labor intensive part to replace. but it would be better to be able to diagnose it more accurately before doing anything, especially since the unit is out of warranty. if a reversing valve is sticking, wouldn't the "swoosh" sound be absent? or have clicks or something? thanks in advance.
    Langley, BC, Canada
    You need to know what the superheat and subcooling temperatures are...without those, your just guessing and replacing parts. I bet you its not the filter dryer, but the temperature difference across it will let you know that.
    *Proud To Be a Member UA LOCAL 516*
    ***GO CANUCKS GO!!!***
    Tn.
    Quote Originally Posted by Crazy4thenucks View Post
    You need to know what the superheat and subcooling temperatures are...without those, your just guessing and replacing parts. I bet you its not the filter dryer, but by taking the temperature difference across it, will let you know.
    Yes, more info. is needed to know whats wrong.
    Could be neither of the two things he mentioned.
    We would need pressures and temp. at different locations to help you.
    Jan 2010
    Hunts. Al.
    could be that metering thingy
    Jul 2002
    Yuma, AZ
    Could be airflow, yadda, yadda.
    "I have never let my schooling interfere with my education."
    Mark Twain
    More at: http://www.quotationspage.com/subjects/education/
    Jun 2007
    Round Rock
    I doubt it is the filter dryer being clogged. The only time I've had a clogged filter dryer is when the tenant of a house, who was a minister. Had a member of his congregation out who did a/c to check the system out and he would give him a couple of bucks to help him out. He was down and out. Somehow this guy got lots and lots of dirt into the system and told the guy/landlord he needed a new system. Ungodly amount of dirt into it. We got called out and cleaned things up. I had to go back about 6 months later and change out 2 clogged filter dryers.
    I like DIY'ers. They pay better to fix.
    Fort Worth, TX
    Quote Originally Posted by snooked321 View Post
    Plus One...
    For the OP: Folks can talk about "what it might be" until the cows come home. Until there's real data gathered, that's all it is...talk.
    - Homer Simpson
    Dec 2001
    Ocean Pines, MD
    Quote Originally Posted by shophound View Post
    Plus One...
    In other word, see Sonic's threads.
    Quote Originally Posted by narfhead22 View Post
    It is best that your company call a proffesional out to diagnose the problem. Who knows - you may and your company can learn some too.
    what were operating conditions?
    narf...............pay attention at this point, if you stick around here and advance, these are going to be pieces of info you will need to bring to the table the first time, getting info to try and solve an issue should not be like pulling hens teeth
    Fort Worth, TX
    Quote Originally Posted by Stamas View Post
    LOL!
    - Homer Simpson
    Apr 2010
    check line temp before and after dryer , temp difference means pressure difference.
    Jul 2002
    Yuma, AZ
    Quote Originally Posted by gzone53 View Post
    I never saw that work on a cap tube system.
    Mark Twain
