Results 1 to 13 of 17
    May 2005
    How much cfm does a 14 and 16 inch pipe pull and how much cfm return air do you need for a 2.5 ton unit?
    Aug 2001
    forney texas
    at 400 cfm per ton to get 1000cfm out you will need to get 1000cfm in.
    SW FL
    Frown A.H.U.
    Originally posted by jel
    How much cfm does a 14 and 16 inch pipe pull ...?
    I always thought the Air Handler blower did the "pulling", NOT the duct.
    Who actually uses PIPE in their A/C air distribution systems?
    16" flexible duct can handle ~ 900 CFM on the return side. A little More if the length is very Short.
    Designer Dan
    Re: A.H.U.
    I do.
    Get back to work.
    Niceville,Fl.
    The flexible duct will handle less then a lot of people seem to give them credit for. The 16 will handle about 1000cfm's at .02" of static pressure , depending on the length as Dan says. If you have a 14 and 16 on a 2.5 ton system you have enough depending again on the length and the path the duct takes straight line is the shortest distance between two points. It's also the best way to run any duct especially flex.
    Too Old to be doing this
    Huntsville,AL
    where are you getting this pipe? I did not know pipe could pull anything!
    I know...it's crazy.
    It's special pipe.
    Get back to work.
    May 2005
    I'm sorry. I am just a home owner trying to determine if I have enough return air. I have a moldy smell coming out of my unit that is making me ill and I am trying to figure out what is causing it. I have had people check it and they say nothing is wrong. I was just wondering if maybe I did not have enough return air. I have 14 inch flex duct to a 20x20 filter and 10 inch flex duct to a 14x20 filter. I just wanted to know if this was adequate. Thanks.
    I know of a company that has 2 locations-one in la and one in sacramento that MAKE sprial PIPE---Its special pipe alright and it takes a special machine to roll the pipe and fold and lock the seams then part the pipe in 10 ft sections
    Ct2, their talking about that new magic pipe. You just put it in the house, and it pulls air, no a/h needed.
    Jel, have they inspected your supply and return ducts for mold.
    Consider having a UV light installed in your system.
    After having any contaiminated ducts cleaned, or replaced.
    Also, use biocide air filters.
    Your return is ok, depending on length, and number of turns, and bends.
    Nov 2000
    Coastal Georgia
    If you grease the inside of the pipe, it will pull more.
    Niceville,Fl.
    Professional mambers
    Don't think the home owner came in here looking for a hard time. Thier just looking for some insight.
