Results 1 to 11 of 11
    I'm getting ready to have my present 13 year old 3 ton AC unit and airhandler replaced. The outside unit is located near a screened porch and there is no suitable area to relocate it to(patio home...very small lot). I live in central South Carolina so the cooling season is 6 months long with pretty high humidity.
    Assuming that I will need a 3 ton unit(my patio home is 1750 s.f. and the exact same plan as 30 others built by the same reputable builder...they all have 3 ton units)what might be good choices for reducing the noise level. Ive heard that some of the very high end equipment has sound levels as low as 67-69 db. Unfortunately, my budget can't accomodate the price of these very high end units.
    Looking for a compromise between absolute lowest sound level and moderate price. I've got a sound blanket on my present Heil unit that hushes the compressor somewhat but the fan noise predominates. I'm not looking to get the absolute cheapest price unit. I'd be willing to spend up to twice what the lesser expensive condensing units cost to lower the outside unit's nosie level to say 72 db or so.
    Thanks,
    Roadking321
    Check out the York Affinity 2 S series.
    They're quit, higher end, r22 units. So they're not as expensive as the 3 S, or 8 T r410a units.
    The york Stealth is not as quit, but close, and you can get it in 2 stage, for alittle more then the r410a 3 S single stage.
    Niceville,Fl.
    Lennox
    Lennox go with a Lennox for quiet operation.
    Too Old to be doing this
    Jan 2002
    Ft.Worth,Tx
    American Standard/Allegiance 13.0
    2A7A3036A1000A-74DB
    York Affinity 12.0/13.0 36,000 72db
    Goodman-13.0 Has lifetime warranty compressor/825rpm motor.
    Nov 2000
    Eastern PA
    Some of the York Affinity's are now down to 6.5 bels
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    burlington county n.j.
    lennox hs26 or hs27 pretty quiet r-22
    xc-21 r-410 very quiet high end price
    SW FL
    Quiet
    XL15 i is the Quietest of the ' MID Range ' TRANE condensers.
    http://www.trane.com/Residential/Pro...ers/XL15i.aspx
    Designer Dan
    Thanks to those of you who replied with recommendations.
    Haven't heard any responses regarding ICP, Rheem/Rudd or Carrier/Bryant equipment recommendations. Any of you out there have any knowledge of mid priced models of these brands that would be quiet?
    Nov 2000
    Eastern PA
    Re: Quiet
    Not that I can really tell the difference, but the York's 65 decibels is 10% quieter then that Trane.
    When it comes to using your name in advertizing, Trane doesn't fare out well with the sound issue. It may be "hard to stop a train" but "you sure can hear a train coming."
    The slope top Tempstar units can be as low as 6.8 on low fan. That would be the quietest 10 SEER you can get. Rheem/Ruud units aren't bad but not that quiet. Only the higher end Bryant/Carrier units with comp blankets would approach the quiet end of things.
    I'm with my Tequilla drinking buddy, I still haven't heard a Choo Choo near as quiet as the Lennox high end, York Affinity or the Carrier Silencers.
    Nov 2000
    Eastern PA
    Even at that, I myself cannot really tell the difference with many of the higher end units today. I installed a Goodman CPLT24 heat pump on the porch of my parents condo. At 72 decibels it is not bad at all sitting right next to it. There is only a sliding glass door between it and my parents TV and it does not interfere with hearing the TV when it is on.
