Results 1 to 13 of 16
Thread: r-22 high head pressure
05-28-2005, 07:03 PM #1
- May 2005
- 3
Need Help with Home A/C Please
I have a rudd condensing unit with R-22, at 90 degrees F. Can anyone please tell me what my suction and high pressure should be? Any help would be GREATLY appreciated. Thanks!
[Edited by david2641 on 05-28-2005 at 07:05 PM]
05-28-2005, 07:18 PM #2
Re: Need Help with Home A/C Please
[QUOTE]Originally posted by david2641
[B]I have a rudd condensing unit with R-22, at 90 degrees F. Can anyone please tell me what my suction and high pressure should be? Any help would be GREATLY appreciated. Thanks!
Between 0 and 120 on the suction side and between 0 and 500 on the high side.
“I am glad that I paid so little attention to good advice; had I abided by it I might have been saved from some of my most valuable mistakes.” - Edna St. Vincent Millay
The critic is a prisoner to his own experiences and perspectives, erroneously believing his limited experiences are the sum of all truth.
No Guns…No Freedom…Know Guns…Know Freedom.
05-28-2005, 07:22 PM #3
- May 2005
- 3
Thank you so much for the speedy response! If you could narrow the ranges down for me it would be very helpful. Can you tell I'm a novice? Thanks again.
05-28-2005, 07:27 PM #4
65 and 250
05-28-2005, 07:27 PM #5
- May 2005
- 4
As a ballpark & it depends on a lot of factors, suction should be in the range of 60 to 80 & head should be in the range of 150 to 300.
I've got a 2.5 ton heatpump, @ 90 degrees in heat mode the suction should be @ 74 and the head should be @ 255.
05-28-2005, 07:33 PM #6
- May 2005
- 3
thank you
Have a good night.You have all been a big help
05-28-2005, 11:05 PM #7
Member
- Mar 2003
- 1,877
pressures dont mean a thing. subcooling and superheat is what you want.
05-29-2005, 01:16 AM #8
If you're not a DIY'er trying to glean this info but rather a novice tech, there's two things you should do. First, find and hold close to your heart a pressure/temperature chart. You can get them at any supply house. Secondly, when you're reading the R22 band on your gauge to get the temperature, look up toward the outermost band of numbers on the gauge. That's the pressure that essentially corresponds to either the evaporating or condensing temperatures of the refrigerant under the given conditions the system is operating at.Originally posted by david2641
Next thing to do is immerse yourself in the world of understanding superheat and subcooling. You do that, you'll set yourself apart from the hacks and be on the way to becoming a sharper technician."In this house we obey the laws of thermodynamics!"
- Homer Simpson
05-29-2005, 07:55 AM #9
I have a pontiac firebird, with 89 octane, at 90 miles an hour, can anybody tell me what it should be taching.
05-29-2005, 08:53 AM #10Look you have to at least give me some kind of gear ratio, for me to answer that question.Originally posted by beenthere
05-29-2005, 10:36 AM #11
LOL...
Do you also need to know if the clutch is engaged, or disengaged. :}
05-29-2005, 11:52 AM #12no more then 3500rpm any more and the old pos will fall apart.Originally posted by beenthere
05-29-2005, 12:02 PM #13Wow! You like it hot don't you? How do you keep it from kicking off on HP switch?Originally posted by mikemike
