Results 1 to 10 of 10
    May 2005
    lawn guyland, ny
    Hmm
    This may seem an odd question but what is the real difference between a pool heater and a standard boiler? The only things that really come to mind are cabinet design to withstand weather exposure and possibly heat exchanger design to account for contaminants like leaves and things that might get past the skimmer.The recovery rate must be the same: 100,000 btu in @ 81% eff. = 81,000 btu/hr.Am I oversimplifying? Any thoughts guys & gals?
    burlington county n.j.
    would a standard boiler hold up to pool chemicals???
    SW FL
    Lightbulb Pool Heater
    Most Pool Heaters should be heat pumps
    ... at least in my area.
    Designer Dan
    It's Not Rocket Science, But It is SCIENCE with "Some Art".
    May 2005
    lawn guyland, ny
    Cast iron? i would hope so. I'm more thinking along the lines of temperature rate - of - rise. dont want the kids getting scalded if in front of the return jet.Also concerned about recovery rate, so many gph x desired rise in temp... that sort of thing.
    p.s. eff heat pumps...
    [Edited by madmark on 05-28-2005 at 12:24 PM]
    Lancaster PA
    You can use a standard boiler, just need to use a brazed plate heat exchanger to protect the boiler.
    Oct 2001
    I think that today's pool heaters have copper - fin heat exchangers.
    Boiler with cast-iron exchanger would take a biting due to condensation.
    In this application primary and secondary loop probably
    would not work.
    Water flow has to be great enough to provide proper filtration.
    Due to high GPM, TD is very small, so I would not wary about
    anybody getting scaled. High temp limit is also lower then in regular
    residential boiler. Pool heaters have a pressure switch to prove the
    pump operation.
    manitowoc wisconsin
    I have used s.s.spiral heat exchangers with good success.
    Take your time & do it right!
    May 2005
    lawn guyland, ny
    ty to all, sigma was the closest. i picked up the heater today. 3 pass copper fin tube HE, proof switch for pump etc...
    Jul 2003
    When using a plate heat exchanger in conjuction with a boiler what are the pros and cons? The boss just told me we are doing a job like this in a few weeks and I was wondering if anyone could shed a little light on what I should be careful with? Thanks.
    Lancaster PA
    Flow rate, flow rate, flow rate.
