Results 1 to 8 of 8
    LCD Temp and Humidity Stat
    Hello,
    Does anyone have any suggestions on a LCD temperature and humidity stat.
    We are looking for one which can show these temps on the LCD display.
    The output from the temperature and humidity needs to go into a controller via a 4-20ma or 0-10 signal.
    And last also provide a setpoint from the stat for temperature.
    Jan 2003
    Do you need both on the display?
    ACI - www.workaci.com has some but I don't think they will display both F & RH on the lcd.
    Dec 2006
    What? Who? Where?
    I was used ones from Veris before. I think BAPI also make one.
    kontrol out
    "Good" - Jocko
    "Open is as open does." - Forrest Gump
    "Can't we all just get a Lon?" - Garry Jack
    "BACnet: integration or interrogation?" - The Janitor
    "Open protocols? You can't handle open protocols!" - Nathan R. Jessup
    “What’s that? Aaa… open protocols? Don’t talk about…. open protocols? Are you kidding me? Open protocols? I just hope we can hardwire an interface!” - Jim Mora Watch it here!
    Near Philly
    I just went through a similar situation. I needed to control a proportional reheat valve 0-10 vdc signal. Display temp and RH%, and provide the info on the BACnet network. I didn't want a central controller, wiring runs are hundreds a feet apart. I found a Viconics device that should do the trick. the problem is the device also has fan speed keys. I talked to Viconics and they said I can purchase a stat cover to hide the keys. I think Veris may sell the same with a different part#.
    Feb 2005
    Jul 2001
    Canada
    Western Oregon
    Silk spyder with Zio module. You can write to the LCD of the Zio module (8 characters).
    RealEyes
    Realize
    RealLies!
    Jul 2001
    Canada
