    Question Insulate Gas Fireplace Insert
    Hi folks, Im in Red Deer Alberta. It gets super cold here.
    I have a signifigant draft from my 1986 gas fireplace insert.
    Should I have the insert replaced? Or will a contractor be able to insulate it somehow?
    Mar 2011
    spokane, washington
    i would get ahold of a contractor in your area and see if you can get a heat activated damper for the chimney because most of that cold air is probably coming down the chimney.
    May 2005
    Madison, WI
    You need a full inspection by a pro to determine where the cold is coming in. Depending on the type of fireplace it is, it might be just the nature of the product, or otherwise a leak in the building envelope behind the fireplace.
