Thread: Pipe thread
05-24-2005, 06:29 PM #1
- Nov 2003
- 18
IM looking for some help I need to seal pipe threads what is the best pipe dope to use I have a brass 1" valve and a 1" schedule 40 pvc adapter with male threads going in to the brass valve Water is going in to a heat pump units water temp 75 to 90 degrees teflon tape and teflon dope doesn't seem to be working. any help will be appreciate Thank you Herman.
05-24-2005, 06:36 PM #2
Member
- Sep 2002
- 229
try another pvc adapter you may have screwed up the threads.Teflon tape and laco blue soft seal, liberally. when tightening make sure yuo use the right size wrenches and you should see a bead of the blue sealant build up as you tighten the fittings. Also make sure you wrap the tape in the propper direction.
hope that helps
05-29-2005, 10:06 AM #3
- Jul 2004
- Red Lion, PA
- 62
Do not use teflon or dope! use a good quality rtv silicone we have had problems in the past with our guys and teflon if you put to much on you can crack or distort the fitting causing a leak. the same for dope it makes the threads seat deeper than normal and can crack the female piece if its say a condensate pan .Ive found that a ring of rtv about a 1/4 way in on the male thread works great and have never had a problem
05-30-2005, 05:58 PM #4
rectorseal
Quote
Engineers like to solve problems. If there are no problems handily available, they will create their own." Scott Adams
"We can't solve problems by using the same kind of thinking we used when we created them."
Albert Einstein
05-30-2005, 08:07 PM #5
I wouldn't mix brass and pvc threaded fittings on a heat pump loop. These joints will leak until the building is bulldozed.
The cheapest solution is to use pvc valves and threaded fittings after. That way you can close the valve and fix the leaks for years to come. The other option, and in my opinion the best, is to flange the fittings. Pvc flange to threaded flange.
Just to clarify, if you dont think the loop temp will ever go above 90f....... The differential in expansion rate will always cause the thread to leaks.
05-30-2005, 08:41 PM #6
- Aug 2002
- 6,047
Your standard PVC dont do heat well. That is why CPVC was developed in the first place.Originally posted by dapper
In industrial sites, that gray PVC is used. It is much more expensive, but it works well and is very sturdy.
Flanges work well. Teflon rope or Teflon string is good for flanged joints.
