Results 1 to 8 of 8
Thread: Tridium Honeywell Wizards
02-28-2011, 10:06 AM #1
I am duing an integration to an older Vykon Jace that was configured with the Honeywell workbench version 3.2.22. I am using EC-NET Pro version 3.2.16. I can connect to the platform ok and see the files such as history and px ok on the Station but I cannot open the network tree. The message says that the module lonHoneywellAxWizards is not present on the machine. (my laptop).
How do I obtain a copy of this module? I have other lonHoneywell modules but not the Ax Wizards. DO I have to use module version 3.2.22 that I am assuming is currently in the Jace and will that run on my version 3.2.16?
Thanks for your help"Controls is a lifestyle not a job" -klrogers
02-28-2011, 10:55 AM #2
emailed jars
You've got mail.
RealEyes
Realize
RealLies!
02-28-2011, 10:59 AM #3
Also if it is an existing JACE you can snatch it/whatever module at the platform level
02-28-2011, 11:01 AM #4
You can try the file transfer utility under the platform view to copy the module from the JACE to your localhost. Wizards are a licensed feature, so I'm not sure if it validates on your local workbench or on the JACE itself.
The feature shows up on a separate Honeywell.license file.
<feature name="XL10Wizards">
PS: 3.2.16 is a fairly older build, the latest maintenance build for 3.2 is currently at 3.2.22
02-28-2011, 11:06 AM #5
02-28-2011, 11:14 AM #6
02-28-2011, 11:18 AM #7
02-28-2011, 01:26 PM #8
Thanks for all the help guys. I am able to open everything now in localhost. I'm not sure if that will still be the case when I connect to the Jace but it is all good now.
