    Under The Milky Way
    CVGE Compressor Overhaul
    Are the tools for the CVGF TOL0148E, TOL0154E and TOL0155E, compatible with the CVGE. I have the CVGF manual but not any literature for the CVGE that might clear this one up ?
    Any information would be good Thanks.
    A problem shared is a problem halved
    A land down under
    The CCGA and CCGB compressors are an original CFC 12 design used on CVGA to CVGD model chillers then adaptated to HFC 134a for CVGE model chillers following the anouncement of the CFC phaseout.
    The CCGC compressor is a HFC 134a optimised designed compressor released with CVGF model chillers and as such requires a completely different set of specialised tools, tolerances and fits for overhaul in comparision to the previous designs
    Under The Milky Way
    I thought so. Thanks.
    Better see if I can find a CVGE compressor manual for the tools list in that case.
    Thank You for the advice.
