Results 14 to 23 of 23
    Aug 2011
    north tonawanda
    new old heatilator in box chimney piece
    I have an old new heatilator chimney piece it is 8" in the id. I am not sure what IC it is as the instructions are with it . If Interested I will email you some pictures. How much is one piece worth.
    Aug 2011
    Does anybody still have some Heatilator IC836 fireplace chimney with 8" ID? I just need one section of it to extend an existing chimney.
    Aug 2011
    Heatilator IC8xx chimney pipes
    greglox,
    Do you still have any IC836 chimeny pipes? I could use a section.
    Aug 2011
    north tonawanda
    HEATILATOR IC824 CHIMNEY SECTION
    Anyone need a chimney section IC824 24" I have one new section still in box.
    Aug 2011
    Heatilator IC824 section
    Yes, I'm interested in that. I'll email your aol address taht you registered with. Thanks!
    Sep 2011
    I know this is an old thread. What are 36in and 48in, 10in OD X 8in ID sections worth?
    Sep 2014
    Hearthman,
    Do you know of anyone with old Temco triple chimney pipe? I have reached roadblock after roadblock. Inner is 8", middle is 11", outer is 13 3/8". We are trying to extend the current chimney without spending the money for a whole new gas fireplace. Our model is #TEC36-1AD. Appreciate your help.
    S.E. Pa
    Gary, I think the last surviving sections of Temco chimney went about 10-15 years ago. There is no approved replacement chimney or repair. I'm afraid your only option is to replace the whole thing. You referred to this as a gas fireplace. This is a woodburning fireplace is it not? Do you mean you have gas logs installed into a factory built woodburning fireplace? Unless I miss my guess, your fireplace is about 30 years old, right? Probably has outlived its useful life anyway. What does the rating plate say?
    Save up until you can replace it with a modern listed gas direct vent that actually provides heat without the danger of flue gas spillage, odors, or sucking 400-600 cfm up the stack. It can also function as a backup heat source during power outages as well as an efficient zone heater. What you have now is junk, no offense.
    Sep 2015
    I know that the part of this thread addressing Heatilator IC836 is from 2011 but I am still curious to see if anyone still has a IC836 available? Below is a thread that I posted this morning. Thanks for any help you can offer.
    We have recently remodeled our house and extended our chimney and I am in need of a 3' section of pipe to complete the project. I currently have a Heatilator model FP36 fireplace. The part that I am needing is the pipe which is Heatilator part number IC836. It has an 8" inside diameter and is 36" long. Does anyone know where one section of this pipe might be available for purchase? Thanks for the help!
    Mar 2016
    I am not interested in that as I am planning to install a new chimney for my home. One of my friends advised me to go with chimney liner installation long island professionals, as they are good at what they do and have experienced experts.
