Results 1 to 13 of 17
    Feb 2007
    milford ct
    true bottle cooler TBB_4G
    Has any one had the pleasure of changing a constant cut in t stat on one of these units ? what a PITA
    If a Ram is a Sheep, And an Ass is a Donkey, Why is a Ram in the Ass a Goose?
    You know the top comes off right?
    Feb 2011
    Baltimore Md.
    thermostat
    put in a ranco a12-701
    haha ive replaced quite a few myself ..... not the easiest but def not the worst but i totally feel u its a b!tch ... im not a fan of these designs but for the end user its perfect lol
    Jan 2010
    Quote Originally Posted by bacciagalupe View Post
    If your a really small guy you can get inside and work.
    st.petersburg,fl
    If you removed the moulding you've opened a can of worms...
    Isn't sanity just a one-trick pony anyway? I mean, all you get is that one trick, rational thinking, but when you're good and crazy, well, the sky's the limit!
    Feb 2007
    milford ct
    #1 you cant even see or feel where the sleeve is for the control capilary . they have it up against the top back wall . of course its full of frozen poped open beer bottles they are open and they want it fixed . so i cant pull it out to remove the doors then pull the top and get it in that way . any other true has a two screw acess and 123 you change the control . i ended up putting in a pig tail style in the coil
    Now your getting the hang of it LOL
    I don't remember it being that hard actually
    PITA Maybe but its just the side panel and a reach around.
    The prep tables are harder IMO with all the mayo and snit over head and that cover with the shelves and supports
    Feb 2007
    milford ct
    def not the same box .glass door undercounter bottle cooler with 3 doors
    st.petersburg,fl
    Lightbulb
    With the cresant shaped evap.... right
    The t-stat is mounted in a long vertical corner panel on the back left corner no?
    Then there is a small chase into the side of the evap and once you get that all down you have to blindly contort your hand and may even need to do a little prying on the god awfull huge drain pan fan shroud to get to the evap tube for the sensing bulb am I close?
    Its not all that hard and you don't need a ladder
    Easy Money
    Jan 2013
    True's refrigerated back bar coolers are designed with enduring quality and value.
    st.petersburg,fl
    Quote Originally Posted by BottleCooler3 View Post
    You haven't worked on your fair share yet or you'd think differently, can't stand True boxes , but they keep me in business
