Results 1 to 7 of 7
Thread: Kills power
    Not in Iran
    Kills power
    Working on rtaa 080. Found fuse blown, kills power to ucp2.
    Due to blowing that fuse. I know I have a dead short somewhere
    Check all motors. Replaced fuse turned on power and when the the machine
    The compressors started it blew fuse again.any ideas
    no signature blast'em man blast'em
    !!!KILL THE TERRORIST!!!
    Not in Iran
    Got it. Condenser fan . Silly me.
    Dec 2003
    45th Parallel
    You might want to inspect the cond fan wires where they are strapped to the underside of fan bracket.
    Sometimes Bruno at the factory cinches them down really tight, and a wire may just happen to be resting on a weld joint on the bracket. If the joint has a little sharp piece of slag....
    POOOOF!!!
    Sometimes they will blow clear and ohm out ok and all fans will work fine, But after time will work their way back to a short condition.
    “If your work speaks for itself, don't interrupt.” ~Henry J. Kaiser
    Jul 2001
    maryland
    Quote Originally Posted by drivewizard View Post
    POOOOF!!!
    I ordered three motors for an RTAC because they blew fuses and didn't ohm out correctly. Put the new ones in and NADA, felt kinda low for awhile.
    Saving the world...one service call at a time.
    Not in Iran
    right on., at least is not a compressor.., oops.,., no i never done that one!
    ottawa canada
    Bad condenser fan motor or wiring to the motors ....Guaranteed . Most likely the wiring as stated .
    Not in Iran
    yep., cond fan., locked up.,
