    Jan 2011
    How to use the timer block in Metasys CCT
    Hello,
    I need help using the timer block in CCT. I'm trying to add it to my logic but it doesn't seem to be working.
    I send a "True" command to it and the output stays "False." Seems like there is nothing I can do to change this.
    Any information you can give will be great.
    Thanks!
    Sep 2006
    Alaska
    Timer
    You need to make sure you set the right type of timer for your application. Once you paster down a timer block, you can double click it and select minimum off, minimum on, off delay, on delay, and pulse.
    Jan 2011
    Thanks for the information.
    I used the Timer in conjunction with a Latch and now it works perfectly!
    Sep 2006
    Alaska
    Great
    Glad it worked out, I know some of this stuff can be pretty frustrating.
