Results 1 to 8 of 8
    Atlanta, Ga. burbs
    What is the purpose of the J trap or P trap <?> that HVAC techs. put on the condensation line from the air handler?
    Thanks. And just curious I have one but just wondered what purpose it serves.
    Tyler, TX
    Same as the trap under your sink.
    They're to prevent sewer gases from infiltrating your house.
    Especially if you have a draw-through evaporator.
    RSES Certificate Member Specialist
    Southwest Regional Association of RSES Secretary, 2017
    Nov 2000
    Upstate, SC
    The trap is to prevent the blower from pulling air up the drain line and holding water in the air handler. Without the trap, a drain on the negative side of the blower will only drain when the blower stops.
    Bobby
    Hell Hole Swamp
    You run condensate lines into the sewer line?
    They break the vacuum created by the blower, or, in the case of a blow thru coil, prevent conditioned air from escaping through the drain line
    Tyler, TX
    When code requires it.
    It does here.
    Mar 2002
    Richmond, Virginia
    Not sure who posted this link on here before, but I saved it for times like this. Happy reading.
    http://www.trane.com/commercial/issues/iaq/iaq5.asp
    There is nothing more frightful than ignorance in action....Mark Twain
    Tyler, TX
    That was me.
    I forgot where I put that!
    Mar 2002
    Richmond, Virginia
    Glad I posted it then. It is informative.
