Results 1 to 7 of 7
    Question
    Can someone tell me the benfits of one over the other. Unit I am needing to replace is AC only, not for heating. Thx
    VS blower, better control of air flow, better control of humidity, cost less to operate.
    Regular a/h, cost less upfront.
    PA/DE area
    also alot less fan noise.
    It's NOT the BRAND,it's the company that installs it!!!!!
    May 2005
    1)Better humidity control, which leads to better comfort.
    2)Lower operating cost.
    3)Lower noise level, especially if running the fan in the "ON" position at the thermostat.
    To get better dehumidification,the VS needs good controls,like Carrier's Infinty.Be sure the control allows you to set the humidity in cooling at the very least.
    Madison, WI/Cape Coral, FL
    Replacing a/c only means that you are going to use the furnace air handler which includes the old fan. But its possible to optimize the air flow to deliver the max latent removal all the time.
    Maximizing the latent capacity,with a psc motor ,won't get as refined of a result ,in most if not all cases.Plus it's better to have the ability to maximize sensible or latent on an as needed basis.
