Results 1 to 2 of 2
    I need help deciding whether to get a 10 Seer or a 14 Seer Trane air conditioning unit. I live in Georgia, so the summers are hot.
    My question is should I get a 10 Seer or 14 Seer. If I go with the 10 Seer, do I get a new coil or keep the existing coil, which is about 23 years old. (The furnace is about 4 years old.)
    Thanks!
    Regardless, you need a new coil. Nothing today will be right with a 23 year old low SEER evap.
    You can't get 14 SEER out of a Choo Choo without a matching variable speed unit. It would be wise in your climate to go above 10 SEER. I'd suggest an XR12 with matching TXV coil.
