    austin
    a customer has a 400 sqf. guesthouse and desires heating and ac in southern california. i know a heat load is best, but its only a single room with two windows. any rules of thumb?
    when life throws me a banjo, i play it
    any rules of thumb?
    Yea , look in the phone book under HVAC or he can always fill one of those windows with a window shaker
    Apr 2005
    Fenestration (light entering via windows, doors, skylites, etc), exposure, and insulation quality will have the greatest effects on the heating / cooling loads. Room size actually has very little to do with it.
    I have a 900 sqft apartment that a 1.5 ton unit can't keep up in hot weather. I have another thats over 1,800 sqft, yet is cooled fine by a 1.5 ton unit.
    If the place is that small, you can do a load analysis by hand using Manual J or ASHRAE residential standards. You can pick up a copy of the ASHRAE standards by buying a copy of the 'Fundamentals' book at ASHRAE.org,. Manual J is more commonly used, but both will give you an accurate answer.
