Thread: drain
    Apr 2005
    if there is a safety pan under the air handler plug the drain with a rag so the vac will pull from the air handler and not the safety pan...
    Apr 2003
    I they were properly installed you wouldn't have to plug that drain!!
    As, they should be independent of each other.
    Mar 2002
    Richmond, Virginia
    Run that by me again? I am not making a connection here.
