Page 11 of 12 FirstFirst ... 456789101112 LastLast
Results 131 to 143 of 147
  1. #131
    California
    131 posts on weighing refrigerant
  2. #132
    Sep 2011
    Plainfield IL
    I always weigh in the proper charge because it eliminates guessing later that its a charge issue if the cooler still dont work right.
  3. #133
    Sep 2015
    Indianapolis ,Ind.
    Quote Originally Posted by mfry View Post
    If you really want to excel in the refrigeration field, don't you think you should now how to do it? And, if you do know how, why wouldn't you?
    You don't need to guess, if you know what you're doing. And, no I don't crank the customer.
    I have only used the scale 2 times in my whole career of 24 years.
    It's like looking at a map when you already know where your going...
    Do to hell with EPA requirements and rgulations.I hope no one turns you or your company in.You really need to reeducate yourself on proper procedures .Even when charging to superheat and subcooling specifications you still need to weigh the refigerant to keep proper documentation and to charge accordingly.
  4. #134
    Southold, NY
    Quote Originally Posted by Rcherry View Post
    What Documentation?
    608 is a huge Joke!!!
    BTW
  5. Likes Jim1959 liked this post
  6. #135
    When installing refrigerant I have both weighed in the refrigerant by the ounce and I have counted the skids of 125 pound cylinders of refrigerant as I added them. Why do you ask?
    PHM
  7. #136
    Feb 2016
    Florida
    Freon has weight?
  8. Dislikes Jim1959 disliked this post
  9. #137
    Jul 2000
    Guayaquil EC
    Quote Originally Posted by joejax View Post
    Freon has weight?
    Yep...I heard somewhere it's measured in tons.
    Check out Icemeister's Back Room
    Read My Latest Rambling:
    What Is Mechanical Subcooling?
    ...and a new calculator:
    Nitrogen Pressure Calculator
  10. Likes pecmsg liked this post
  11. #138
    Feb 2016
    Florida
    She's gonna blow!!
  12. #139
    How about that? And here all this time I thought it was measured in dollars.
    PHM
    Quote Originally Posted by icemeister View Post
    PHM
  13. #140
    Feb 2016
    Florida
    Boss Hogg said that wasn't part of the 'quote' .....
  14. #141
    Aug 2017
    You should always weigh in critical charge units it is designed to work with a specific amount of ref. If it ain't workin right with the right amount something else is wrong
  15. #142
    Virginia
    Scales are for sissies....
  16. Likes joejax liked this post
  17. #143
    Did I read this wrong originally?
    Are you asking if I weigh-it-in ?
    Or are you asking if I use a scale as opposed to guessing?
    I do use a scale - unless the charge is measured in cylinders rather than pounds.
    I can only rarely remember ever fully 'weighing in a charge'. That is: charging with the cylinder actually on the scale and me watching the numbers fall.
    PHM
