Results 1 to 13 of 15
    Feb 2011
    Melbourne Australia
    Question split system is this odd ??
    sore this the other day any one know what would cause it ?
    temperature drop over the indoor unit is only 2 degrees ?
    not looking to fix it just curious of the cause, from what my friend told me some one installed it about a year ago work fine till now
    Jan 2011
    not normal, most-likely low on charge but it could also have a different issue. have you checked the washable filter (if it is a mini)
    Dec 2003
    south NJ shore area
    Valve hung up or open ... fludded txv
    GOOD WORK IS NOT CHEAP! AND CHEAP WORK IS NOT GOOD!
    IF YOU THINK A GOOD HVAC COMPANY IS EXPENSIVE. THEN YOU SHOULD TRY A BAD ONE.
    Feb 2011
    Melbourne Australia
    its not low on gas it's r22 the gas was at 900 kpa. off. checking the specs that is normal once on cooling it dramatically drops like very low about 50kpa.
    Feb 2011
    Melbourne Australia
    The line freezing up is the liquid line
    Jul 2002
    Yuma, AZ
    Check your air filter, Mate.
    What's a kpa? Can ya translated into old English units for us? We kind of like psig.
    "I have never let my schooling interfere with my education."
    Mark Twain
    More at: http://www.quotationspage.com/subjects/education/
    Apr 2005
    Quote Originally Posted by phs View Post
    No....the line freezing up is not the liquid line, and if you only have 2 degree diff inside then your coil is froze. turn off system let everything melt. and have HVAC guy check your pressure.
    Jason J Saylor
    Lockheed Martin
    HVAC Tech
    Meymanah,Afghanistan
    "You will encounter many distractions and many temptations to put your goals aside: The security of a job, a wife who wants kids, Whatever. But if you hang in there, always following your vision, I have no doubt you will succeed.”
    Larry Flynt quote
    Nov 2001
    east kansas
    The little line is either a liquid line or mixed phase line. If it is a mixed phase line it needs to be insulated. The difference between the two lines is where the metering device is located.
    The little line looks oily and that is where I'd look first for a problem.
    A system can still be undercharge and the pressure will match the PT chart when not running.
    Beware of advice given by some guy on the Internet.
    Jan 2011
    Lynchburg, VA
    900 kPa = 130 psig
    50 kPa = 7.3 psig
    kPa is normally an absolute pressure, but I am assuming that he is talking in terms of gauge measurement. Atmospheric pressure is a bit over 100 kPa.
    houston, texas
    Appears to be 5/8 which would make it the suction line. Your coil is probably frozen and you can't figure out anything till you thaw it out completely. Take a flashlight and look up through the louvers and find the blower wheel, could be quite dirty.
    I'm not tolerating Political Correctness anymore, from now on it's tell it like it is.
    Veto Pro Pak - The best tool bag you'll ever own
    Feb 2011
    Melbourne Australia
    It's the liquid line it's 1/4 " that's how much it's frozen. the suction at the bottom is 3/8 where the service valve is . it's a 2.5 kw unit . I checked the presure with gauges. 1.5 deg . Is in C not F it's 34.7 deg F
    Jul 2002
    Yuma, AZ
    Look inside of the unit to see if the frost continues inside and where the frost ends (or begins). There has to be a restriction at the point where the frost begins. (If this is the liquid line as you say.)
    Mark Twain
    May 2010
    Pretty sure that's the suction line that's frozen up. Check blower and clean coils. Also check air filter. Might possibly have a leak
