Results 1 to 10 of 10
Thread: white moisture
    May 2005
    Has anyone heard the term white moisture in a refrigerant circuit
    Mar 2002
    Richmond, Virginia
    I have not. Could that be Ice?
    There is nothing more frightful than ignorance in action....Mark Twain
    Sep 2003
    It sounds like what may be seen at the exhaust port of a vacuum pump when there is a little refrigerant in the system.
    May 2005
    I was going behind a gas company tech who had condemned a 7 year old carrier system he said was contaiminated with white moisture. I looked at the unit today and found the the txv was defective. I had never heard the term white moisture must be a gas company exclusive. thanks for the input
    Jun 2001
    The gas company is now servicing refrigeration circuits ?
    Was he refering to the furnace possibly ? Ash is white.
    Senior Tech Guest
    White moisture...canoot valves... flux capacitors...I believe they come from the same family.
    I started in the Gas company union in 74... he is bull sheeeting and has no idea what day it is.
    He probably opened up a valve cap and spewed some oil on his little tender fingers.
    perhaps the gas man meant condensation forming and dripping through the flue connections.
    i encounter this all the time with unlined chimneys.
    homeowners do not always have thier terminology right.
    [Edited by billva on 05-10-2005 at 10:04 PM]
    Senior Tech Guest
    Carbonic acid.
    Madison, WI/Cape Coral, FL
    Oil mixed with water in a blender makes mayonaise. Compressor is the blender. Oil and water- priceless!
