Results 1 to 13 of 13
Thread: Trane RTHD
    Feb 2011
    richmond, va
    Trane RTHD
    hey we just pick up a new contract that has two RTHDs and i was worderin if there is any type of software that i need, or can i just view eveything at the display. I have not work with a RTHD yet but i work with RTAA and RTAC alot, anything different i need to no?
    Dec 2003
    45th Parallel
    You can use the same software and cable that you use for the RTAC.
    “If your work speaks for itself, don't interrupt.” ~Henry J. Kaiser
    Quote Originally Posted by JWOO View Post
    ...anything different i need to no?...
    no condensor fans or fins on the RTWD and you occasionally have to pull pudding samples and send them in for analysis!
    Mar 2010
    Va.
    Some of the pudding setpoints will have to be changed with the pudding software and with the pudding cable.
    MEXICO
    you would have to download the software for rthd, cable or usb and techview is the same for RTHD, RTAC, rtwd.
    god luck
    Nov 2013
    Tech View T V . 14
    Dear All Masters of HVAC,
    I am new in this field. I am a Facility Manager and basically an Electrical Engineer, interested in solving control circuit issues.
    We have three numbers of 400 TR RTHD Chillers from Trane.
    I want to know that, can we do all maintenance like replacement of spares (sensors, Expansion Valves) with the help of Tech View TV. 14 without the Help of Trane Local Service Technicians.
    Please advice.
    Gireesh
    - - - Updated - - -
    Tech View T V . 14
    Please advice.
    Gireesh
    Oct 2006
    Central Texas
    Gireesh,
    "Basically an Electrical Engineer?"- alright. Yep, you can do all that you're looking to do without the help of Trane (or mechanical conractor). What you have to ask yourself is "How well do I know what I am looking at ?" RTHD's are very sensitive chillers, not to doubt your ability, make sure you have a back up plan in case problems arise. Make sure you do daily logs and keep a close eye on tower control.
    Sic Semper Tyrannis.
    Nov 2013
    Thank You Very much Sir.
    At present the temperature is showing in Degree Fahrenheit . Is it possible to change to Degree Celsius.
    Gireesh
    MEXICO
    if possible change celcius to farenheit
    The Hot South
    I'm an HVAC tech and basically a mechanical engineer and yes, you can do all the maintenance yourself. Like txhvac said, you need to know what your doing though.
    May 2013
    Quote Originally Posted by R123 View Post
    its guys like these that keep me even busier
    The Hot South
    Quote Originally Posted by traneguy123 View Post
    Me too. They usually have good intensions and want to save money. In the long run, they usually spend more.
    ottawa canada
    You can count on that .
