Results 1 to 13 of 15
    Jan 2011
    Carol Stream, IL
    Confused American Standard RTU YCD150 testing.
    Hi everyone, I'm very new in the field of HVAC, and I'm working with a compmany in general maintenance. They allow me to check the RTU's and figure out what is wrong with it and fix them, which is a new experience for me becaouse I was tring in residential. Well however I have this American Standar RTU that onece the t-stat reach room temp. the hole unit turn off except the inducer motor keeps and running. The LED stays on as normar not telling me any thing. The model # is YCD150D3H0BB. In short words I can not determine what is wrong with it. Some help pls.
    Apr 2010
    Minnesota
    Trane had a service bulletin on this problem a few years ago. Trane and A/S are the same thing. If I remember correctly the problem was a short in the power burner motor. Maybe someone around here will be able to produce that service bulletin so you can test it. I found one of these this summer on a 25 ton, the hot humid air was condensing inside the heat exchanger until it started dripping rusty water onto the cash registers down below!!
    P.S. I suggest you get someone with more experience to help you with this. Good luck
    Jan 2011
    Carol Stream, IL
    Thank you very much for your reply. I will try to get the bulletin. And unfortunately I don't know any one with more experience. But I really appreciate your help. Thank you again.
    Jan 2010
    Go figure another Trane combustion blower motor running away. Like they say hard to stop a trane.
    Apr 2010
    Minnesota
    No problem, and welcome to the site. I fairly new here too. I'm trying to get a little bit more active around here now that we're down to 40 hrs a week again.
    Apr 2010
    Minnesota
    Feb 2011
    ycd150 is i believe a single speed draft blower, if solid state controlled u have a stuck clix on relay if controlled by a board the board blower relay is stuck closed
    Last edited by rr75beep; 02-16-2011 at 09:53 PM. Reason: common problem with trane voyagers you might want to also check the heat exchanger, this problem will rot them out
    Southeastern Pa
    Okay. Here's what you do.
    Follow this bulletin.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Southeastern Pa
    A side question.
    Who thought it was a good idea to take a guy who has no experience on Trane RTU's, new to the field, and not give him someone to show him how to approach these things?
    Sounds like you are working for people who lack the first clue themselves....
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Jan 2011
    Carol Stream, IL
    This is awesome!!!!! thank you very much. could you tell me how did you get this kind of info?
    Southeastern Pa
    Quote Originally Posted by fiscalito71 View Post
    The same way you just did.
    Consider applying for Pro membership. There is a LOT in the Pro areas of the site.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Jan 2011
    Carol Stream, IL
    No it is not that, this is a company who owns some buildings and they hired me as maintenance but taking advantage of my certification they gave me the chance to start checking the unit. If i'm able to fix them they would save some money and I will get experience.
    Jan 2011
    Carol Stream, IL
    yes i will, when i have enogh posts.
Tags for this Thread
