Thread: Temp Sensor
    Dec 2003
    I've got a 100k ohm duct sensor I'd like to install on a unit to get a DAT, we have SBT controls, and I think a standard sensor for that system is 1k ohm. Is there anything I can do to make my sensor work, or do I have to get a 1k ohm?
    Still learning....
    Apr 2005
    Montreal
    Depends on what type of controller from SBT you are talking about. TEC can accept a 100K sensor, and 10K. MBC can take it too if you have a 100K module.
    Dec 2003
    Today I pulled all the wire and installed the sensor, I found an unused AI in my MEC and landed the wires there. I created a new LAI point, then I selected Thermistor 100 KOhm from the menu and calculated slope/intercept. When I ran a point log on the point, I got an outrageous value... over 10,000F and it had *F*. I changed it to just about every sensor there was, and it kept telling me the point was Failed.... Why? Does this mean there is a break in my wiring, did I wire it wrong in the MEC, I'm really confused now... Tomorrow I'm going to put a meter on it and check it out, does anyone else have any ideas??? Thanks.
    Still learning....
    Apr 2005
    Inland Empire,CA
    Don't know much about MEC, but ALC has bird jumpers on the inputs for 4-20ma, 0-5vdc, and thermistor/dry contact. Jumper needs to set in right position. Is there a needed gain value on your thermistors? Just a thought.
    Apr 2005
    Montreal
    The standard MEC doesn't take 100K ohm sensors. Even if you can calculate a slope and intercept for it, it won't give a good reading, regardless of jumper position.
    Dec 2003
    Well, I got my hands on a 1 KOhm and moved the jumper in the MEC and everything worked great. Thanks for your help!
    Still learning....
