Thread: FHP Plugged Coax
02-15-2011, 09:40 PM #1
New Guest
- Feb 2011
- 1
FHP Plugged Coax
I have a customer that has a 3T FHP Open loop discharging into a creek. The water quality is not good. However, their FHP has a plugged coax 100%. I've tried flushing from the leaving to the entering and vise versa. I have also tried blowing it out with nitrogen. I could try using chemical to flush however, I don't have much faith that it will work since I'm not getting any water out at all or nitrogen. Any ideas other than replacing the coax and or unit?
02-16-2011, 08:16 AM #2
- May 2005
- 148
I ran open loop for awhile until it clogged. Then I cleaned it out with Muriatic acid and switched to closed loop. Did you try Muriatic acid?
02-17-2011, 08:23 PM #3
- Feb 2004
- Pacific NW
- 522
Get your post count up and apply for pro memebership and there are some good 'solutions'.
FWIW, the HCl mentioned is excellent for Ca and Mg deposits......
