Results 1 to 13 of 22
    Hussman M# LBN6 ice cream case has a paragon mechanical defrost timer that is a 48 hour timer but has a 24 hour face dial, what is with that. Also, what should the defrost interval and derost time settings be?
    Saddle Up!
    Southold, NY
    Need the #'s on the clock. Is it pressure or temperature termation???
    temperature termination
    Saddle Up!
    Southold, NY
    Paragon 8145-10/20 (10-110 V 20-220 V) Every 6 hrs 45min is your starting point. Adjust hr's & Min for the application and area.
    Thank you for your response however, it sounds a little too generic for what I was looking for. I was looking for something a bit more specific seeings how it is an unusual time clock
    Saddle Up!
    Southold, NY
    Give me more info. open display,Coffen case, Glass door's etc. What temperature and product???
    24 or 48 hr clock should not make a diff.
    Sep 2001
    East Stroudsburg, PA
    Don't recognize the #, but an LNGH with electric defrost would call for 60 minutes, terminating at 48 degrees, once every 24 hours.
    Sep 2001
    Exclamation
    Under ideal temp/humidity/loading conditions, that is.....
    Jul 2000
    Guayaquil, EC
    Hussmann LBN6.......
    As I recall, the LBN was a Gloversville case called the "Lowboy", hence the LB. The N stood for no front glass. They had standard Paragon (or Precision) clocks like the 8145-00 or 8141-00.
    The defrost heaters only defrost the upper gravity coil and often only one defrost per day is necessary, like Dave said. You want to make sure the heater limit and termination is working or you'll be replacing the element real soon.
    [Edited by icemeister on 05-07-2005 at 07:40 AM]
    It is a low boy but it does have sliding glass doors, they are oriented horizontally and open from front to back, hoping the customer closes it all the way. There is an upper deck with electric heaters. The case is used for ice cream. The clock is mechanical clock but instead of 24 hour it is a 48 hour??. Just never seen a 48 hour clock. The face of the clocks dial has 24 hour increments. Does the clock run at half speed. I can get the clocks model # on Monday.
    Saddle Up!
    Sep 2001
    Paragon makes a 48 hour timer, but it doesn't have a 24 hour face on it, that I know of. I've never seen it used in a defrost application.
    They also make 3,5 and 7 day timers.
    What's telling you that it's a 48 hour timer?
    Oh well, could be worse, could be a Precision....
    The sticker on the time clock says its a 48 hour time clock. I'll post more about it on Monday
    Saddle Up!
    Sep 2001
    Does it resemble THIS UNIT???
