Page 3 of 3 FirstFirst 123
Results 27 to 32 of 32
  1. #27
    Monmouth Junction-NJ-USA
    Alco??? ugggghhhh. But your choice. Wrong flavor valve??? All the more reason to dump the refrigerant. If someone put the wrong valve in, or didnt change it during a conversion, who knows what else is incorrect. R-22 replacement is inexpensive for a smiling and happy customer.
    If you really know how it works, you have an execellent chance of fixin' er up!
    Tomorrow is promised to no one...
  2. #28
    Alberta, Canada
    Here is a chart I was given a long time back that I think is a invaluable tool for people to read, Learn and memorize. It may just help you in your current problem, at least start to point you in the right direction.
  3. #29
    Jun 2001
    Michigan
    On my Blackberry at my hip. It's an awesome guide.
  4. #30
    Originally posted by flangehead
    call backs suck
    That's why we can't take anything for granted.
    Anybody else miss the days when Low temp was always R-502, Medium temp was R-12, and R-22 was just for air conditioning...
  5. #31
    Jul 2001
    Gold Coast of Connecticut
    What makes you believe the cooler was not a r-134a or r-12 unit. I hope the compressor was rated for r-22 or it will go boom!
    Aire Serv of SW Connecticut- Gas heat, dual fuel and central a/c systems installed and serviced
  6. #32
    May 2005
    Calgary, Alberta, Canada
    And I thought only I was blessed with these kind of nightmares. Once found an old walk-in cooler that didn't work worth a damn. The tag that was nicely attached to the condensing unit by the last tech. stated that he had repaired a leak and charged with r-22. Head was ridiculous and very poor evap. performance. Long story short here.
    Eventually I cleaned all the grease and years of build-up off the unit and found it was originally an R-12 unit.
    But wait it got worse. The compressor was a recently installed medium temp R-404a/R-507 unit. To top it all off the TX was correct.......for the original condensing unit.
    So I was standing there looking at an R-12 condensing unit with a medium temp. R404a/R507 compressor feeding an R-12 TXV using R-22 as the refrigerant. Try to explain that to the customer.
    Yes we have air conditioning in our igloos.
