    Aug 2009
    Dunwoody GA
    Help Matching Evap Coil
    Can anyone help me with details as to which evap coils to purchase. Two story load calculation available. Original builder installed 2 ton condensers and 2 ton evap coils. 75,000 BTU furnaces. Upstairs has 200 more sq.ft. than downstairs. No total square footage available. Should I upsize the upstairs to 2.5 tons?? Purchasing two Lennox XC14 single stage condensers up to 16.20 SEER, and two 80% furnaces. I can't seem to find much information as to what evap coil I should purchase to get maximum efficiency....Can anyone help?? Thanks, Dillard.
    Feb 2011
    You will probably get more views if you post this in the Residential HVAC section. As for the match-up's on the equipment you listed, you should be able to find this information on the Lennox web site or by contacting your local Lennox dealer.
    Nov 2010
    Welcome to the site. This is the introduction area only. You need to post this in residential hvac.
    Good luck.
    The statement below is my signature and just my overall feeling towards our industry and does not necessarily pertain to you nor this thread.
    There really isn't a legitimate excuse for not doing the job correctly!
Tags for this Thread
