Thread: Carrier 23xl
    Carrier 23xl
    Hi Folks,
    I'm new here and it's my first post. I'm from Brazil and need Help in a Carrier 23XL that i'm working on.
    Actually machine is running but i have a alert message "High condenser pressure". I read some parameters that may help all:
    Evaporator Refrig temp: 11,3c
    Evaporator Pressure: 606,8 Kpa
    Condenser Refrig Temp: 41,6c
    Condenser Pressure: 1490,7Kpa
    Discharge Temp: 56,8c
    Oil Sump Temp: 56,8c
    At Pic II i also have:
    CHW in: 18,3c
    CHW out: 15c
    CDW in: 27c
    CDW out: 34c
    MTR AMP 80%
    So if any one have ideas to help my chiller i would apprechiate a message.
    Thanks in advanced!
    philadelphia
    are your tubes clean and condenser water flow correct?
    Jan 2005
    Houston TX
    Your Condenser approach
    I would be looking at dirty or blocked tubes as your condenser approach is almost 14*F (8*C) . How many pass is your condenser, you may be by-passing water through a division plate. Just a few ideas -GEO
    Of all the things I have lost in my life, I miss my mind the most-GEO
Tags for this Thread
