    I am looking at an old carrier evap coil M#28RD030000 S#V811264.
    Would any one happen to have info on what tonnage this coil is?
    May 2005
    Cincinnati, Ohio and Northern Kentucky
    Looking at your model number shows me that your evaporator coil is a 2.5 ton.....Rule of thumb I USE when looking at model numbers to determine size is....looking at the first three numbers after a letter.....012= 1ton 018= 1.5ton
    024= 2ton 030= 2.5ton 036= 3ton and so on... also remember to divide those first three numbers by twelve to get your tonnage.
    Nov 2000
    Eastern PA
    That only means that that coil was capable of being matched with a 2.5 ton unit in the year it was manufactured. That does not at all mean it is properly sized for a unit manufactured today.
    Indoor coils don't really have a capacity. The capacity of a system is determined by the condenser/heat pump.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Thanks for the Rule of thumb herb c, I will remember that.
    Robo,you mean to say that a 2.5 ton condenser manufactured today will not go with this evaporator?
