Results 1 to 13 of 14
    Miami Florida
    Compression fittings for liquid and suction line??
    Some new condensor units come with compression fittings to attach the liquid and suction lines to the condensor. Is this just as good as brazing???
    Sep 2001
    Vancouver Canada
    Haven't seen any yet, which units have you seen with compression?
    Nov 2001
    How can it be ?
    It goes back to the self piercing lineset days.
    And leaks soon after.
    If you try to fail, and succeed.
    Which have you done ?
    Apr 2003
    You sure wouldn't be installing one for anyone I know, there junk. Complete junk!
    North St Paul MN
    Is he talking about mini-splits?
    I'd rather have a bottle in front of me, than a frontal lobotomy.
    Nov 2000
    Eastern PA
    Are you talking about compression fittings or flare fittings? I don't know of anyone using compression fittings and they have never been considered suitable for refrigeration, as far as I am aware.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Carrier used them for years on there a/h,that where you always found the leak.
    Fort Worth, TX
    Yep. I recently found one on a Carrier heat pump air handler. Even the instructions that came with the unit had directions on how to repair the leak by sweating. If they knew in advance the connection might be problematic, wouldn't it be better to make one that was not rather than write alternate leak repair instructions? Sure doesn't reflect well on that genius design.
    Building Physics Rule #2:
    Building Physics Rule #3:
    Nov 2000
    Ottawa, On. Canada
    Smile compression fittings
    back in the 80's when I was doing quite a bit of residential work we were handling Climatrol and Fedders units. These had compression fittings and were a real pain for leaks. York also had them on the old Champion units (looked like a tombstone). The best way I found was to use the compression fitting and then StaBrite the joint.
    Dave
    Apr 2004
    Swagelok
    A properly applied Swagelok compression fitting will NOT leak.
    Many years ago while doing some R&D work the Swagelok fitting was used to build up systems. They passed helium mass spectrometry leak testing and have been used for years in other industries.
    Brazing or soldering is much cheaper and very reliable.
    The only time a compression fitting makes sense is when brazing is not practicle or unsafe.
    http://www.swagelok.com
    Oct 2012
    Those fittings
    Quote Originally Posted by gary6768 View Post
    I've seen them on new Trane units. Take a peek into the condenser unit and they are on the compressor. Also, pop your car hood. Nothing but compression types. The flare types hold tight. The ones in the old auto are used with aluminum though. It's a very soft metal.
    Sep 2009
    Acworth, GA
    .... Halloween must be very close... It seems there is another grave of a old dead thread coming back alive...... Ahhhhhhhhhhhhhhhhhhhhhhhh
    Runnn ... Hide behind your service trucks..... Lolllll
    Mar 2009
    Mid-Mo
    Quote Originally Posted by AC Talker View Post
    Are you talking about the rotolock fittings? I've found them to be pretty reliable. If they do leak it's either from working loss or the line not being lined up perfectly when it's installed. Easier said than done on a 30 ton scroll....
