Results 1 to 14 of 14
Thread: Problems with Trane XC95
    Oct 2009
    Virginia
    Just installed a Trane TUHM060. Venting with 3", LP converted. When unit fires up at 65% the valve is throttling rapidly, after about 3 min the outlet pressure has reduced to 0"wc and unit shuts down. The in coming pressure also throttles between 11" and 15" but seem to be caused by the furnace gas valve. if I disconnect the pressure hose on the positive pressure port a gas valve, the unit will run( still throttling) but pressure doesnt drop. After about 8 mins and unit reaches 70% capacity the pressure smooths out and unit runs great. I can only achieve this with that pressure hose disconnected from the gas valve though.
    Its not the gas valve.
    Jun 2006
    New Jersey
    And I've been warned about given hints in the public forums.
    Quote Originally Posted by ascj View Post
    But I didn't tell him to check the flux capacitor, so I think I'm safe.
    Oct 2009
    Virginia
    Just trying to get a couple ideas before I call Trane on Monday. Nothing I cam do until then anyway. I appreciate it
    Oct 2009
    Virginia
    What happened to this site? Techs could talk to other techs, i guess I'm not cool enough to talk to the big boys anymore. You guys rock!
    They still can. Just for the last 4 or 5 years, its done in the pro forums.
    Your not registered under 2 names are you.
    Oct 2009
    Virginia
    I signed up originally around 2000 and forgot my password and username, I had to open a new account, I think I got booted do to inactivity
    I see there is another account from the same company. Signed up in June 2009 I believe.
    Oct 2009
    Virginia
    I am not sure, I see the link to apply for professional membership. So I will do that.
    Oct 2009
    Virginia
    FYI. Trane is developing a new LP gas valve to fix this problem. Fix for now is to set thermostat to single stage operation.
    Aug 2010
    N.E. Indiana
    FYI, I believe the new gas valve for propane is available now. May cure your problem. Ask dealer about new valve.
  14. #14
    Oct 2009
    Virginia
    Confused
    Nice of them to give me the wrong one on Friday
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
