Results 1 to 10 of 10
Thread: Question about a stepdown transformer
    Dec 2010
    Hello,
    I am looking to find the rated amps for the sencondary of a stepdown transformer. Three phase primary is 460/575V, secondary 230V, 200VA. I am not sure if I should calculate the secondary side of the transformer as 3 phase or single since it is only 2 wires coming out of the secondary.
    Calculations:
    3 phase- 200/230/1.73= .5 Amps
    Single Phase- 200/230= .87 Amps
    I am not sure which is correct and I could really use the help thanks.
    Jul 2000
    Dallas,Texas
    There are no three phase transformers, just multple transformers placed together in a package.
    In this case you have 1 transformer fed from 3 phase. However it is only tied to 2 of the 3 phases.
    2 wires in 2 wires out, figure it as single phase.
    IF this was a three phase transformer your calculation is incorect.
    You have to allow for the 3 phases of power.
    The equation is I = (KVA x 1000)/ (1.73 x E)
    Assume this is a 20KVA 3 phase transformer instead of 200VA single phase.
    (20 x 1000) / (1.73 x 230)
    20000 / 397.9 = 50.26 amps
    May 2010
    If it only has two wires coming out of the secondary it is single phase. I am not sure I understand you by saying, "There are no three phase transformers" when in fact there are? They are in delta or wye configurations
    Dec 2010
    Thanks for the help
    Aug 2000
    Austell, Ga.
    The "Only" thing Wolfdog has been in error about is his chosing a puny 9mm against a full house 45ACP. His statement that there is no such thing as a 3ph. transformer is correct. Just because a 3ph transformer looks good on a schematic diagram, in all actuality it is nothing more than single phase transformers connected in Delta-Delta, Wye-Delta or Delta-Wye configuration.
    Now....If I could only get da' Wolfdog seeing straight on the 9mm/45 issue all would be well.
    Ain't "None" of us as smart as "All" of us..
    May 2010
    I'd rather have a 9mm over a 45 as well, for many reasons. That is why I carry a 9mm and not a 45acp
    Jul 2000
    Dallas,Texas
    I'm open to negotiation RichardL.
    Quote Originally Posted by RichardL View Post
    don't forget wye-wye...but who would use those? stupid triplens!
    as for the transformer...i do not believe that he has a 3 phase transformer PRIMARY and a single phase SECONDARY. my guess is that his transformer is a multi-tap PRIMARY transformer.
    approximately 0.87 amps would be correct for 230 VAC, single phase.
    "Right" is not the same as "Wise".
    Just because you can measure it, doesn't mean it is important. Just because you can't measure it, doesn't mean it isn't important.
    Jul 2000
    Dallas,Texas
    I don't believe I have ever met a Wye/Wye transformer configuration.
    Delta/Delta for isolation and/or step down.
    Delta/wye to produce a neutral and/or step down.
    Wye/delta to step up.
    The obvious question is Wye?
    Jun 2010
    Philadelphia PA
    Richardl both choices less than optimal
    40 cal better ballistics and knockdown!
    You have got to learn from other people's mistakes! Because God knows you don't live long enough to make them all yourself !!!!!!!!
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
