Results 1 to 2 of 2
    Feb 2011
    Flow Cross Backwards
    What would be the affect of a flow cross on a VAV supply or exhaust box installed in the opposite direction of airflow? Would the cfm readings,differential pressure readings be way off? I came across an exhaust vav installed backwards.
    Jun 2010
    Philadelphia PA
    with the small intake and larger discharge ( this is VAV and not a VVT damper) how would that be possible?
