    May 2009
    Commercial Hot Water boiler leak
    noticed slow seeping leak that is showing up at floor level at the mid section on both sides of a 16 section hot water boiler (boiler is about 10 yrs old; not chemical water treatment).
    seems to be a slow leak
    question - what is causing it? will it get worse and
    can anything be done mid way thru winter or just live with it till end of heating season?
    how serious to repair?
    Sep 2006
    Ohio
    If it is a Cast Iron Sectional Boiler, the rubber seal most likely needs to be replaced between the sections. This would be a big job but needs to be done ASAP. You should shut down the boiler right away and call a boiler repair company.
    Oct 2007
    Had a school with a leaking boiler section in the middle of a 16 section boiler. Installed a I beam above boiler with a dolly and chain hoist to move each section down enough to replace the gaskets in between this was a peerless boiler and it used carbon gaskets and they are expensive . From experince ispect the leaking section very carefully I had to tear this boiler down a second time to replace the section that was leaking because of a hairline crack it wasent the gaskets.
    Jun 2006
    New Jersey
    Who said it was a leaking section?
    Get a contractor out to identify where the leak is coming from. I can't tell you how many times, I get the call for a school with a leaking section. And something completely different causing the water.
    Here's just one example-
    http://hvac-talk.com/vbb/showthread.php?t=687041
    Mar 2011
    Canada
    i have a burnham with some powerflame gas burners on it. leaking the middle section. these r the older style burnhams before they switch to american boiler.
