Page 7 of 10 FirstFirst 12345678910 LastLast
Results 79 to 91 of 126
  1. #79
    wedged in freezer shelf
    You can slip the sensors out of the 1250 or 550 clamps. The SMAN3 comes with beaded TC sensors also. Strap the sensor only to a pipe and use the clamps for some glue project in the garage
  2. #80
    Nov 2007
    Sherman, TX
    okay, I misunderstood what you were saying....
    Technical incompetence is NOT a sales tool....
  3. #81
    The K-type thermistors are more available. the clamps are grat especially for checking superheat, I would not reccomend removing them for some glue project. This is my second pair and they do everything. They make work fun again.
  4. #82
    Quote Originally Posted by draisland7 View Post
    Are you referring to K-type Thermocouples?
    They actually have more types of Thermistors on the shelf at my J-Mart.
    IMO Clamps are lousy for checking SH, SC or anything for that matter.
    You seem happy with them so I couldn't probably even prove it to you but you really believe it is possible for a pipe clamp to be more accurate than a sensor properly insulated from external ambient.
    What temp clamp are you so happy with?
    I've haven't had so much fun till I've started measuring actual pipe temperatures and it is something special if you have found a clamp capable of that.
  5. #83
    Sep 2010
    Ontario Canada
    I know you keep pounding this issue home, but I have zero issue with pipe clamps, nor does other people around here.
    You're Only As Good As Your Last Service Call or Install.....Make it Count!
  6. #84
    Nov 2007
    Sherman, TX
    Quote Originally Posted by Ingersoll AC View Post
    I've used a Fluke 80T-150U probe, plugged into the meter du jour for years with great results, and am now just starting to use K-clamps.
  7. #85
    Well clearly I am doing something wrong then Eh?
    Thanks for pointing that out.
    I will try harder
  8. #86
    Pipe clamps work very well for me also, nice to have everything in one tool
    SMAN 3 is the way to go.
  9. #87
    Quote Originally Posted by John Markl View Post
    That's an odd one John.
    Is that a Thermistor to mV generator?
    Did yours come with this?
    http://www.myflukestore.com/crm_uplo..._datasheet.pdf
    Lots of good info about EMF mV issues and ambient error in there.
    Good read for those who haven't picked up on any issues.
  10. #88
    Nov 2007
    Sherman, TX
    Yes, you plug it into your amprobe or VOM, and set it to mV.
    When measuring superheat, I typically poke it thru the insultube to hold it against the suction line.
    It also comes in handy for other things, like sticking it in the honeycomb air outlet on a supermarket case, or sticking it into a supply or return grill and leaving it there for a while to stabilize. I was using this probe for these purposes long before infared guns became common and affordable.
    I have no quarrel with those who wish to tout the virtues of their chosen instruments. I'm merely sharing what I've satisfactorily used....and will continue to use.
  11. #89
    Are you saying you use I/R with success now?
  12. #90
    Did anyone turn on that microwave while you were taking temperature measurements?
    Those will eff with your meter. Try it
    How about that scale?
    Not sure about this wireless but you can find out for us.
  13. #91
    Apr 2004
    Charlotte, NC
    I guess this delay is still going on. I ordered 2 a month ago from my local URI. Now they're telling me 2 more weeks. This is discouraging.
    "Fighting Ignorance since 1973 (It’s taking longer than we thought)." The Straight Dope.
