Results 1 to 9 of 9
    Jan 2011
    York Gas valve spring located
    Installing a York furnace that my friend gave me model P1XUB12V05501D. It is a 2 stages variable speed. It was previous converted to propane and now I am converting it back to gas. I have the spring but could not find the regulator screw head anywhere. When second stage kick on all I got was 1.6" WC no matter how tight I tighten the allen key. Its need to be at 3.5"wc
    Round Lake IL
    it takes more then the spring to convert it back.
    Jan 2011
    I change the orifices already back to #45 it were #56
    Round Lake IL
    This is not a diy site and we can not help you with it. If you dont no where the screw is you should not be doing this.As not doing it right and get you hurt or burn down your house. call a pro in and get it set up right.
    why isn't your friend doing it for you?
    Jan 2011
    I am is an installer, I normally install Trane. I not familiar with this White Rodgers gas valve that is why I ask for help. Gas valve is a 36E54-250. If I am not an installer how do I know about Water Column and about changing the spring and orfice
    i used to work with this clown that had the vocabulary down,unfortunately that's all
    fwiw
    Jan 2011
    replaced with a 36E55 221 and working perfectly
    Lancaster PA
    Quote Originally Posted by natra911 View Post
    A couple searches on the internet, and I could sound like I know how to fly an airplane.
    An I'm not a pilot.
