    Apr 2005
    I need advice on my Carrier split system. The fan coil located in the attic is rusting on the lower wing of the coil. The installer says that this is expected and not to be concerned with it. Given that the system is less than four years old I am concerned. Although the system works I do not think rust is acceptable. Is this an installation issue? Contractor was out several times a few years ago to empty the secondary pan. He finally changed the white drain pipe. Should I have the coil replaced? Should I have the unit replaced? How can rusting be minimized in the future? Thank you for your help.
    Nov 2001
    east kansas
    It will rust don't worry about it.
    Midlothian, Virginia
    i see em everyday that old and rusting
    Goodbyee stranger it's been nice. Hope you find your paradise! Hey it aint rocket science, "It's a Trade !"
    I have seen lots of horizontal cased and air handler A coils that the end sheet of the bottom half was rusted almost completely away with no ill affects on the system.
    It isn't unusual to find one <5 years old where I can reach in and break off pieces of the end sheet with my fingers.
