FORM 201.19-NM2 (204) this is the form that you should be setting your motor protectors and your mp voltage up in micro panel at the very least verify those settings not SB0022 call and find out if can get the design spec's for that Chiller then you will know what your dealing with.
A mind is like a parachute. It doesn't work if it is not open.
The best part of going to work is coming back home at the end of the day.
Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all.
