Results 1 to 12 of 12
04-29-2005, 10:42 AM #1
- Apr 2005
- 14
OK, I'm up here in Canada and have a newly installed Carrier Infinity thermostat which appears that it only supports Fahrenheit. I went through manual and all configuration screens and can't seem to find an option to display temperatures in Celsius (???). 1-800-CARRIER told me it can, but won't provide details !!! Can anybody help? Thanks!
04-29-2005, 10:57 AM #2
Call your contractor before things get messed up.
He'll help you...How tall are you Private???!!!!
04-29-2005, 11:14 AM #3
- Mar 2005
- Indianapolis, IN
- 241
Yes you can,
You need to go into install service menu.
( Hold advanced button for 20 seconds )
Enter setup, at the setup proceed to
"english/metric display", select C.
Don't mess with any other settings.
Brian
[Edited by browntigerus on 04-29-2005 at 11:17 AM]
04-29-2005, 12:15 PM #4
Member
- Jan 2005
- 86
Made a mistake. Deleted the post
[Edited by deme on 04-30-2005 at 12:14 AM]
10-12-2005, 12:48 PM #5
- Sep 2005
- Ontario
- 19
fractional celcius degrees?
Glad to hear that the Infinity tstat can display Celcius (C)degrees. But ...
Does anyone know if the user interface can accept/display fractional degree Celcius?
1C degree change is equal 1.8F degree change. It would be a major disappointment if temporary setpoints had to be whole celcius degrees.
10-12-2005, 03:29 PM #6
- Apr 2005
- 14
Yes, unfortunately it can not do fractional degrees (in F or C), but seriously I don't find that such a big deal since I already have a lot of air temp stratification in my home (yes, with furnace fan & ERV running continuously).
And incidentally, I had to educate my so-called contractor on how to operate the thermostat (!!).
[Edited by robroy on 10-12-2005 at 04:33 PM]
10-12-2005, 05:24 PM #7
Banned
- Aug 2002
- Office and warehouse in both Crystal River & New Port Richey ,FL
- 18,836
It does 100ths of a degree internally,just won't display that way.
10-12-2005, 07:22 PM #8Hi Dash: In the fahrenheit scale does the Carrier Thermidistat register in 100ths internally too? When they explain in the thermidistat operating instructions it says that the anticipator is ajustable range from 1 to 9, default is 3.Is this 1 to 9 range 100ths of a degree? I would like to add when I had my thermidstat in the fahrenheit scale(it's installed in the hall right outside of the main bathroom)it would activate when ever anybody walked by it. I tryed adjusting it all the way to 9, but didn't seem to make much difference. So recently I put in the Celcius scale with the same anticipator selection and it didn't seem to be as sensitive when anybody walked by it. Any ideas?Originally posted by dash
Thanks, Thorton
[Edited by thorton on 10-12-2005 at 07:52 PM]
10-12-2005, 08:01 PM #9
Banned
- Aug 2002
- 18,836
I don't know about the Thermidistat and 100ths,doubt it does,as it was a tauted feature of Infinity.
10-12-2005, 08:42 PM #10
- Sep 2005
- Ontario
- 19
The fact remains that the resolution at the tstat UI for setting a setpoint is almost twice as coarse when using Celcius.posted by dash
The internal resolution only gives the tstat the potential of maintaining/predicting the setpoint given the appropriate algorithm.
10-17-2005, 12:24 AM #11
Member-bad email
- Aug 2004
- Great White North
- 92
robroy: How's it going, eh? I ran my Infinity on deg C for a while and found the temp swings in the house were too much. Depending on what I had it set at, either it got just a wee bit too cool before the heat would come on or it would get just a wee bit too hot before the heat would go off. As mentioned, that's because 1 deg C equals 1.8 deg F.
So, I switched to deg F and things are better, now. Basically, running it on deg F is the same as having fractional settings for deg C (like 20.5 (68.9), 21.0 (69.8), 21.5 (70.7)).
The only problem is, if you are a young 'un, you don't know what Fahrenheit is... It's like something you only heard about... ;-)
Just be careful if you decide to switch to Fahrenheit. If someone squeels on you the Metric police will be knocking on your door...ha, ha...
10-17-2005, 09:59 AM #12
- Apr 2005
- 14
Hey Garry, it's goin' grrrrrrrreat, eh! I haven't gone through a heating cycle yet in my new home so I may have to switch back to F for more granularity .. we'll see soon enough (brrrrrr, getting cold already!). Sorry, gotta run to Timmy's for a double double...
