Results 1 to 13 of 16
Thread: Fuse puller?
    Indiana
    Fuse puller?
    Do they make a large fuse puller? One for fuses the diameter of a quarter or larger? I have just used my pliers an i know this is not the best way....can screw up the tag then you may be SOL on size
    Mount Airy, MD
    Real men just reach in there and grab them babies
    Channel Locks here..........
    Emerald Coast
    Google: greenlee or cooper bussman.
    460 always tightens me up.
    Do not attempt vast projects with
    half vast experience and ideas.
    Jul 2010
    So-Cal
    These work
    Oct 2005
    Canada
    Quote Originally Posted by jackintheboxtec View Post
    These work
    yes those ideals I have a couple sizes of ideal part #34 0200a should get it
    Remember: Murphy's Law,
    Newtons Law of Gravity, Einsteins Theory of Relativity..then you won't go to far wrong.
    Mar 2006
    Albany NY
    These work
    i got the same pair... get em
    Quote Originally Posted by yellowirenut View Post
    Yea, it 's called a channel locks
    Jul 2010
    I use one like this:
    Rapid City, SD
    I wanted one for fuses, mostly smaller one's... the office sent me on I'm pretty sure could grab a fuse 1" in dia or larger with one end. It's about 16" long, and a major pain to use.
    Yup they do! I believe they got it from grainger.
    Indiana
    Quote Originally Posted by amickracing View Post
    Ahh grainger
    http://www.grainger.com/Grainger/wwg...n_dim_search=1
    Nov 2010
    Maryland
    I always use channel locks, just turn off the disconnect and grab em from the load side not the line side. The amperes is always stamped into the copper at the end of the fuse don't worry about fudging up the label and if you need to know what size fuse to put in a disconnect, then we need to start a new thread.
    New Hampshire
    Ideal 34-002. Probably one of my most used tools.
    Oct 2005
    Canada
    Probably the best way to do it using approved tools
    Additionally if in a plant use the necessary PPE for the job
