Results 1 to 8 of 8
    Jan 2006
    Hamilton Ontario Canada
    Fieldpiece Meter
    Ok what Fieldpiece meter will do everything I need for residential. Gas furnace,gas boilers, AC, ductless splits anything else they can throw at me. Right now I am using the Fluke 902 and also carry the Fluke 116 for doing thermocouples and the Fluke 52 for temperatures. So a meter than can do MVdc,UAdc, amps,ohms,microfarands,temperature and anything else I may need.
    louisville, ky
    Sc77 or the new sc56, both will do all u need for under 200
    Jan 2006
    Quote Originally Posted by Vettgetsmwet04 View Post
    Checking out the meters you suggested will they read MVdc for testing thermocouples?
    Sep 2010
    Ontario Canada
    HS36 as well.
    You're Only As Good As Your Last Service Call or Install.....Make it Count!
    yep
    louisville, ky
    yes, i own the sc 77, it does everything, it autoranges on all scales, its a clamp meter so u can hook it to stuff when checking other measurements. goes upto 40 meg ohms. ive never had a grounded comp it would read. the sc56 is on my list, i pulled the trigger on the sman 3 last week. so ill wait til this sumer for the sc 56. ive had the sc77 for almost 2 years now, not a single problem.
    Sep 2009
    Stumptown,USA
    DITTO
    DITTO
    Challenge yourself, take the CM test --- Certificate Member since 2004 ---Join RSES ---the HVAC/R training authority ---www.rses.org
    Oct 2009
    Kingsport, Tennessee
    If your still looking for a meter and interested in the Fieldpiece sc56. You may want to check Johnstone Supply March 1st, there might be a good sale going on......sshhhhhhh.
