Results 1 to 12 of 12
Thread: propane furnace
    Apr 2005
    new jersey
    im possibly doing a new house in pa in the fall.the homeowner is asking for price on 1 zone propane and 2 zone propane heating system.im assuming their is no natural gas in the area.oil/propane only.my question is is it ok for propane converted furnace in the attic area?and the other in the basement?maybe 1 zone oil located in the basement is the way.thanks for any thoughts on the subject.
    Urbandale IA. USA
    I have seen too many LP 90+ furnaces that SOOT up when the gas company FORGOT to keep the tank full.
    I will NOT install an LP furnace with out a gas low preasure shutoff.
    my 2 cents.
    What about hot water heat?
    New Hampshire
    my 2 cents.
    Thats bizarre. I've never heard of that one.
    Maybe they were using the old style single stage regulators at the tank.
    New Hampshire
    I don't see why not. But check local codes.
    It might get more attention(service) if the furnace is easily accessible or in a large second floor closet.
    But chances are the units will be oversized, unless the house is really big.
    You might consider zone dampers with one furnace in the basement.
    [Edited by oil lp man on 04-28-2005 at 01:47 PM]
    New Hampshire
    Go with hot water heat. Unless you need central AC.
    Huntsville,AL
    NOT good!!!
    propane is heaver than air!
    so with any leak, propane may fill the living space = BOOM!
    better increase your insurance 400%
    Apr 2003
    Originally posted by cem-bsee
    NOT good!!!
    On whose standards?
    LP equipment is no more of a danger than any other correctly installed and serviced equipment.
    midwest
    NOT good!!!
    On whose standards?
    I agree, and there is nothing wrong using LP in any install that you would use natural gas. I have never seen or heard of a furnace sooting up because of the tank being out of gas and 50% of my installs are on LP. They have to be serviced just like any other furnace to prevent problems and my guess would be the sooting problem had nothing to do with running out of gas.
    Apr 2003
    ICP has two LP conversion kits, one with and one without this pressure switch.
    I always install the PS kit. It's just good practice. What if one of the regulars freezes up (or malfunctions) a little and now the unit is operating at a lower gas pressure? It will soot, and that makes for one bad service call! (especially if 90+)
    I have to agree with jultzya and trane. There is nothing wrong with propane furnaces even in the basement. Around here you have no choice outside the city limits. Electricity for heat is cost phrobitive around here. And for those who make comments about leaks in the basement filling up with propane and going boom. What about natural gas leaking and filling the upstairs and going boom? The only sooting problems I have seen is when the old ribbon burners start to flake and rust. I get called then because the furnace won't put out any heat.
    South/West of Quebec in the other part of Canada
    It is not a good idea to install anything hi efficiency in the attic. If a furnace problem goes unnoticed it could freeze the secondary heat exchanger. Think about a hi efficiency boiler and remote hydronic air handlers with glychol solution, you can use this system for domestic hot water aswell with an indirect hot water tank..
    Huntsville,AL
    how about gas packs? that is what is used around this area -- whole unit sits OUTSIDE.
