Thread: carrier 48ZJ055-6
04-27-2005, 11:57 PM #1
- Aug 2002
- manitowoc wisconsin
- 4,687
I have a few of these units that have some issues & I was wondering if anyone else was having the same problems.The main problem is ignition boards.In the past year to year & a half I have replaced three boards between two units.These units are only a few years old.They have all had the same malfunction.All three boards have had the inducer relay contacts welded together & the bottom left hand corner of the board is burned up.I know they had some problems with inducer motors but that is not the case here.motors,voltage,& amp draw all fall in line when checked out.Also the verticle supply air deck next to the condensor section is bowed on one unit & broken/buckled on another.I have also noticed that the V.F.D. is mounted in line with the fan motor v-belt and is picking up rubber on the cooling fan for the V.F.D.These are not small rooftops.I was wondering if anyone else had to tell a customer that a fairly new 48ZJ055-6 was popping ignition boards left & right,had broken air decks,or V.F.D.'s loading up with v-belt rubber!
Take your time & do it right!
04-28-2005, 08:13 AM #2
- Nov 2004
- 240
Mark,
Have you contacted your local Carrier distributor service manager?
04-28-2005, 11:37 PM #3
- Aug 2002
- 4,687
yes we have had them out on these units for board problems before.I was wondering if anyone else has had probs with these.
08-02-2005, 12:24 AM #4
- Aug 2002
- 4,687
I have bee having alot of trouble with pressure transducers on these units as of late.The spa & dpa transducers were replaced last week........tonight I was back again with codes 51,67,&69.code 51 was the high pressure switch opening.call for cooling & no condenser fans for circuit a.Both week old transducers failed to calibrate & the wiring was ohmed out & tested good.here goes round two I will go back tomorrow & replace both transducers again & test the dc power supply.It always gets my goat when a week old part fails!
