Results 1 to 13 of 25
Thread: Goodman
    I have recently started a project were I will be using 500 units 10 seer goodman. Goodman is offer a credit to the builder to use there product. What should I expect for warrenty calls? any percentages?
    Nov 2000
    Eastern PA
    Depends 100% on how you install them.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    SW FL
    Reliability
    Can you name another MFG and lower SEER that may provide Less quality and reliability?
    Designer Dan
    Apr 2003
    Iowa
    I would have checked into the rebates and put in a 12 to 14 seer, better warranty too. Might cost about the same after rebates. Careful with coil cleaner, it seems to not like goodman paint.
    Nov 2000
    Eastern PA
    Goodman paint is the same as any other brands paint and coil cleaner will damage any finish. You guys really are absurd. When are you going to learn it's all the same stuff and sell application, installation and service instead of product?
    Nov 2000
    Eastern PA
    Re: Reliability
    With comparitive ratings, they are all the same, using the same vendor parts and the same ferrous metal for cabinetry. While some units have more features and may be quieter, they are still basically the same.
    The Goodman line is doing well and is a nice fit for the application you need it for.
    Check out http://www.Goodmanmfg.com to get a detailed view of their products and warranties.
    What application?
    Low cost?
    chicago suburbs
    [QUOTE]Originally posted by mdac2001
    I have recently started a project were I will be using 500 units 10 seer goodman. Goodman is offer a credit to the builder to use there product. What should I expect for warrenty calls? any percentages? [/QUOTE
    no comment.
    FILL OUT YOUR PROFILE!!
    leland nc
    as tinner said
    What application?
    Low cost? [/B][/QUOTE]
    Any heating & cooling application, smart a$$.
    And yes, low cost is always a nice feature.
    Jun 2000
    NC
    I once worked with a contractor that did apartment buildings and with them there it was about 1 percent that had problems and then with goodman it your cookie.
    Nov 2000
    Eastern PA
    I don't understand this.
