Results 1 to 7 of 7
Thread: Trane XR90
    Apr 2005
    Welland, Ontario, Canada
    Opinions please on this Trane model.
    Any known problems?
    TUX040 direct vent is what I'm looking at
    Apr 2003
    Iowa
    Good furnace.... put in a bunch.. had a vent motor make a noise... replaced under warranty
    haven't had a call for a 40 though.... you must live in the south
    what are the ratings for this unit? thanks.
    Apr 2003
    Eugene, Oregon
    Any known problems?
    I can't look at any links until my confuser is repaired, therefore I can' check your profile. Thurston as in Thurston High School?
    Proud supporter of Springfield Millers and Oregon Ducks.
    Rochester, MN
    It's a 40,000 BTU system (37,000BTU) 92% enegery effecney.
    They are good single stage system w/ regular blower motor.
    The control board has been a royal pain in the #$##$. Hopefully the bugs are worked out by now. They've covered everything I've replaced under warranty so they are taking care of us. Not a reason to avoid this model, since I have a dim view of most of what's being made today, but you asked. A long parts & labor warranty is a good buy regardless of unit chosen.
    Apr 2003
    Iowa
    Loonie....... speaking of bugs.. Lady bugs..beatles whatever they are callin em this week... only one I have changed a circuit board in was soaked with water. The new units I believe even have a water deflector on top of it. Anyway this lady's A-Coil was full of lady bugs and plugged the A-Coil drain.... overflowed and dripped thru furnace, therefore soaking the circuit board... Other than that no problems. My book says 92.1 but who's counting...Trane rates their units at the lowest efficiency it will get... NOT the highest like most of them.
