Thread: ch530
    North America
    ch530
    Hello all
    I'm working on a retrofit ch 530 I am having issues binding. I was wondering if I can get someone to forward me a troubleshoot manual on this. I believe that the power supply board maybe damaged. There was a short on the communication bus.
    Thanks in advance
    Jun 2010
    Tampa, FL
    ch530 retros are't sold any more. Sure you don't have an adaptaview? If your com bus is shorted it will not communicate but it should not harm power supply board. If power bus shorts the on board fuse blows. Unplug all buss plugs at the power supply board. Do you have 24v on the output pins? With plugs off com should be up. Plug in one at a time until you loose com. That's the problem buss wire. Work your way up or down the wire disconnecting one at a time until you find the problem LLID. If it is the older flat wire buss have fun. The problem is often in a clamshell. Might be better to rewire with the newer bus with automotive connectors, although it would still need and adapter at each LLID. I don't think there is a troubleshoot manual. If you have access to tech support they can walk you through it.
    Jan 2005
    Not in Iran
    i have .,.,.,hehe
    no signature blast'em man blast'em
    !!!KILL THE TERRORIST!!!
